Winter break in
Old 02-10-2007 | 02:08 PM
Default Winter break in
Ive got a new 91fx and am ready to break her in. With the cold temperature outside in the teens would it hurt anything to break it in?
Old 02-10-2007 | 02:15 PM
Motorboy's Avatar
Default RE: Winter break in
I live in Norway who are cold in winter, can not hurt the engine while break-in the engine.. But it can make difficult to start the engine if the battery for glow plug are poor or too cold.
Jens Eirik
Old 02-10-2007 | 03:40 PM
wjvail's Avatar
Heat the upper cylinder with a torch first and use a little lighter fluid in the carb to get 'er going. Some foil tape over the fins might help... Or, like motorboy said, just start it... OS's come with a pretty comfortable fit to begin with. Something like a squeaky tight Rossi, Jett or older K&B performance engine might need more attention but you should be OK with an OS.
Bill Vail
www.RCScreenProtectors.com
Old 02-10-2007 | 08:13 PM
proptop's Avatar
My Feedback: (8)
The .91FX is ringed, correct? A ringed engines first runs aren't quite as critical as to ambient temp. (IMO )
Is it going in your air boat?
If so, I would just cruise around for the first tank at a rather rich setting, then lean it out to a slightly rich 2 cycling mode for the 2nd tank, and after a few more tanks that way, you should be good to wail on it [8D]
Old 02-10-2007 | 08:20 PM
wjvail's Avatar
Oh yea... ringed... I forgot that part. Sorry.
Just run it a little rich for a few tanks.
Bill
Old 02-10-2007 | 09:36 PM
Thanks alot for the advice.
Yes its going in my airboat, at five and a half pounds with the 91 it ought to be interesting
