Muffler Performance
Old 02-18-2007 | 11:24 AM
Default Muffler Performance
Has anyone out there ever put a saito 100 muffler on a saito 72 or 82? If so, what sort of performance changes if any did you see?
Thank you
Old 02-18-2007 | 11:48 AM
Default RE: Muffler Performance
Hi!
You will see no changes besides less money in your wallet ..!
Old 02-18-2007 | 12:06 PM
P-40 DRIVER's Avatar
Why not just take the muffler off completely and see if you get a performance gain. A saito will run just fine with no muffler pressure assuming you reset your needles and put the tank where it should be. I doubt you will see much, but it would be a worthy experiment. Fastest way to more power out of a Saito is 30% heli fuel and the the best prop for your application. I would start with working on finding the best prop combo first.
