os40la
Old 02-15-2003 | 02:22 AM
tld
Default os40la
problem i have is that the engine runs fine for about 10 minutes smokeing good tnen it will put out less smoke an start to bog down an putting out less smoke i can let it idle for a few minutes an go back to full throtle an it will run agian for a few minutes any idles thanks
Old 02-15-2003 | 02:55 AM
w8ye's Avatar
My Feedback: (16)
Default os40la
It could be going lean on you?
It could be that you do not have the top end rich enough?
It could be that there is a problem with your fuel system?
You could have too large prop on it? Use a 10-6
You could have it cowled in where its not getting enough air?
Good luck,
Jim
Old 02-15-2003 | 03:01 AM
tld
Default os40la
does the nedle adjustment need to be level with tank are does it need to be lower are higher than tank thanks
Old 02-15-2003 | 03:04 AM
w8ye's Avatar
My Feedback: (16)
Default os40la
The center of the needle needs to be exactly in line with the center of the tank.
Jim
Old 02-15-2003 | 03:07 AM
tld
Default os40la
ok thanks the nedle is below the tank now i will put nedle with center of tank maybe that will fix it thanks
