OPS four stroke OHC
NE
OPS four stroke OHC
Bought an OPS overhead cam four stroke from a guy here in town. Did a search here but could only find info on their two stroke boat engines. He didn't know what size it is, thought maybe a .120 or a .150. Does anyone know about these? What size they make, what props to use. Is there anywhere to find the toothed belt that drives the cam? I know they aren't common, but any info would be much appreciated. Ross
BC, CANADA
1 Post
RE: OPS four stroke OHC
Hello; I recall that they were offered in two valve and four valve versions, with the four valve ones being the rarer. The only one AI've seen is the two valve.
I have a card of OPS 4-stroke plugs the suit the OPS 4-stroke engines.
They are by far the hottest 4-stroke plugs I have ever handled.
Similar in style to the Fox Miracle or O.S. " F ". Other makes of 4 stroke detonate at high RPM's using them, and as such they are totally unsuited to other 4-strokes.
I will send them (I think I have 4 of them) to anyone who has an OPS 4-Stroke engine for the cost of postage. Even if the engine is a collector peice, it would be nice to some of the factory specified plugs to go with it.
fiery
fiery
NE
SON OF PALEFACE, I found a source for belts at www.sdp-si.com. The belt was ok on the engine when I got it. I simply wanted a new one before trying to start it. I also installed all new bearings while it was apart. and found that it is a "non-interference" engine, i.e., the valves won't contact the piston if it jumps time. This is good because I've been told they strip the belt teeth on a prop strike. Of course, like any poppet valve four stroke, I'm sure it will bend valves if over-revved to where the valves "float". They are beautiful engines. Needle bearings support the cam and lower sprocket shaft. The lower rod-end has needles also. I don't really want to sell this one, but will keep an eye out for you. It seems like when I buy something like this, I end up seeing more (usually cheaper!) [>:]after the deal is done. Ross
My Feedback: (90)
I ran one a lot when it became available in the 80's. It was comparable to the OS and Enya 60's of the day. It looks massive but isn't and is relatively light. It's a 120 obviously. Had mine converted to CHS ignition and ran 16/7 or 8 props on it on a Roadrunner. Was a great combination and the motor was usually a one or 2 flip hand starter. I never suffered a prop strike and when I got rid of the plane and motor a few years ago the motor was still in excellent condition. I have a NIB but probably will just keep it in the collection.
dennis
dennis
HEY GUYS
I JUST GET AN ALMOST NEW OPS 120 FOUR STROKE,BYT IDONT KNOW FROM WHERE I'LL FOUND ,GLOW PLUGS.
IF SOMEONE KNOWS, PLEASE INFORM ME.
WE ARE PERSONS OF THE SAME FAMILY{AIRMODELLERS}.
TEO THE GREEK
TEO THE GREEK
ID
Hobbsy That is a impressive engine , I really have my doubts about early valve float due to the fact theres no push rods or lifters to deal with. Be about the same as a modern day 4 bangers in the cars we drive, minus the injection of course*L* The only thing I can see that could make it better would be a gear set up instead of the belt.
Do you know what sort of a tensioner it has to keep the belt tight?
