engine choice
I need an engine .20 to .32 and I have narrowed it down to between a GWS .25 abc bb or an OS .25 la. The OS is about 6 dollars more and I just don't know if the GWS is a good engine or not so I don't know if saveing a few dollars is worth it in the long run... suggestions??
Thanks all
Thanks all
DOH!!! it is a GMS.. so sorry.[sm=red_smile.gif] its actually a cheapo arf I got from Hobby Lobby called a sky baby with a 52" wing span. Picked it up for just $30 so I figured if it flys like garbage and I crash it, so what..
Banned
If you're looking at the GMS25 then don't bother -- go for the GMS32. It's the same size and weight but has more power and you can always use the throttle to reduce that power if needs be.
Better check also MVVS; especially at those sizes the MVVS is in the price of GMS and has
the performance ... of OS.MAX if not better even for some cases.
Cheers,
Nick
Cheers,
Nick
