where to get a con rod for a max-S .35 R/C ?
My Feedback: (264)
MD
I know it is a long shot finding a new part for this old engine. I would just throw this engine in the spare parts bin or use it as a paper weight, except the rest of the engine is in pretty good condition. The rod is pretty worn at the wrist pin and crankpin ends, it about .003" to .004" out of round at both ends. A replacement would extend the life of this engine for many years.
Any ideas? If I were to have a rod made, what would be the best material to make it from? 7075, or 6061 maybe?, The original has no bronze bushings.
Thanks, Mike
Thanks, Mike
My Feedback: (16)
RE: where to get a con rod for a max-S .35 R/C ?
This guy can make you one if you send him your engine
Frank C Bowman
1211 N Allen Ave
Farmington, NM 87401-3568
505-327-0696
[email protected]
Frank C Bowman
1211 N Allen Ave
505-327-0696
[email protected]
My Feedback: (264)
MD
I did a search and there was a post saying he was no longer making rods. I'll email frank now and see if that is still the case.
Mike
Mike
My Feedback: (264)
MD
That's out of round, not pin clearance. I used a mitutoyo digital caliper to measure, it's not perfect for measuring small holes, but close enough. You can really feel there is excessive slop in the rod when you rock the crank back and forth with the piston @TDC. I'm sure if I were to run it this way, there would be alot of clicking noises from the engine. The piston to sleeve and crankshaft fit are good to go.
