Enya 35x Heli Engine on a Magic
Any comments on using an Enya 35x heli motor on a 3D Magic?
Not sure if you can/should do this with a heli motor or what the problems would be.
Thanks for your help.
Eric
Eric
My Feedback: (90)
Really can't think of any reason not to . A heli motor is the same as any other motor except for the heat sink head and sometimes a different carb. Your biggest problem with a heli motor is to have enough crankshaft length to get the prop, washer nut ,and spinner on.
Eric,
I have a TT36 heli motor on a magic and love it. I use an aluminum prop nut with no problems so far, turning APC 11/3 or 11/4 props. Check out the pics in the funfly forum.
Good luck,
Steve
Good luck,
Steve
