Scared of Backfiring
Old 02-26-2003 | 06:10 PM
Default Scared of Backfiring
Hi All,
I bought myself a Carson Stormracer for Xmas and its been working fine. Recently I bought a new glow plug (Mtronics quickfire), when I fitted it the engine started ok, but when I reved up it backfired and blew the seal between the engine and exhaust I replaced the seal and now it barely starts at all and when I rev it backfires. I'm afraid to start it now in case I break it.
Help (new and confused)
Old 02-26-2003 | 06:42 PM
Ernie Misner's Avatar
Greetings - can you tell us more about that Carson Stormracer engine? Is it a 4 stroke by any chance? Try richening it up and see if it quits backfiring and then lean it back out ever so slowly.
Ernie
Old 02-27-2003 | 08:37 AM
Sorry new to RC,the box says 0.15, 2.5cc, 4 stroke
engine it also says to use 10 - 20% fuel. I tried running it a bit rich and it stopped backfiring but when I remove the glow starter the engine cuts out. Is it just getting the main needle and carburettor (that may not be spelt right)set up right. I read something about plugs being too hot
somewhere should I just put the old plug back. What is a good plug/temp to use/run at. Sorry for so many questions I appreciate the help.(2.5 not 3.5cc for anyone who read this)
Old 02-27-2003 | 11:25 AM
Rudeboy's Avatar
I took a look at their site... it is a 2.5 cc two-stroke buggy engine...
Old 02-27-2003 | 12:13 PM
Plug is to hot. try Rossi R4 or R5. Or put your old plug back in.
Old 02-27-2003 | 01:46 PM
I couldnt get rossi plugs but I did get one with alower rating and I'm up and running again. Thanksfor your responses. (happy but still confused)
