Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Thunder Tiger 1.20 PROBLEM ??? HELP !! >
Old 09-03-2002 | 02:09 PM
Default Thunder Tiger 1.20 PROBLEM ??? HELP !!
How does it idle?
Old 09-05-2002 | 01:19 PM
Try adjusting the low speed needle for the idle and mid range. I am not an expert tuner but if the high end is ok then you need to go to the other adjustment. My experience with TT engines has been ok. I had one that was stubborn to start and another one that ran all the time like a top. Maybe the carb is faulty in some way?
