Enya .80 4C
Hi folks,
My flying buddy, who does not hang out on RCU, has an Enya .80-4C NIB he bought in 1987. Does anybody here have any experience with this engine? What we are wondering is primarily performance-wise - we are thinking about what aircraft it may end up in.
I currently fly a Saito .72, and I would guess the Enya, due to it's vintage, would be a bit behind that in power, but I do not know for sure. The recommended prop sizes, operating rpm range etc are all similar. I'm thinking it's most probable first home will be something sport aerobatic in the 2C .40-.46 size range.
Any info/advice would be appreciated.
MJD
MJD
My Feedback: (14)
ORIGINAL: MJD
Hi folks,
MJD
Hi folks,
MJD
Once broken-in and set up properly, your .72 will have a difficult time matching the Enya 80-4C (really a .74). Your .72 is much lighter and more compact and that is an advantage. But when it comes to producing power, the Enya is going to be tough to beat. Especially if your friend uses a 13x6 prop. It will pull a 14x6, but it really shines on the 13x6. Mine would pull my CGM Cub with the full size wing well enough to climb in knife-edge. The Enya 80-4C is a strong engine, but it is a little on the heavy side.
Ed Cregger
ORIGINAL: Ed Cregger
Ed Cregger
Ed Cregger
The Saito .72 works best on the 13-6 too, at least on my Pizazz which although a great horsing around aerobatic airplane is IMHO between 1/2 and 1 pound too heavy for it's size. But it is loads of fun, and the .72 will pull it vertically indefinitely, albeit not too fast.
Cheers,
MJD
I got (as a gift ) an Enya .80-4C in a Pica 1/5 scale Aeronca Sedan, which weighed in at about 12.5 lbs.
It would fly it in a scale like manner...
It had a 14X6 on it when I got it, and that wound up being the best prop for that situation. I tried an APC 15X4W which improved take-off and climb performance, but I had to keep a higher power setting @ cruise...(as you could imagine )
Both of the above props would turn about the same r.p.m. of around 8,700 on 10% Powermaster.
My Feedback: (14)
ORIGINAL: wcmorrison
Anybody know where I can get an Enya 80 head. I have a friend looking for one.
Cheers,
chip
Cheers,
chip
Have your friend go to www.enya-engine.com and write Ken Enya an email requesting the particulars on that 80-4C cylinder head. Ken is usually fast to respond and his prices aren't bad either.
Ed Cregger
ORIGINAL: Ed Cregger N2ECW
Ed Cregger
Ed Cregger
MJD
My Feedback: (14)
As a well worn aside (from me), the .80 isn't really an .80. It is a .74. I did the math one day and that's the number that came up. It makes me wonder why engine manufacturers do this sort of thing.
On the other hand, it is a fine engine and I really do like my 60-4C and 80-4C four-stroke engines.
Ed Cregger
Ed Cregger
