Things to come
Old 03-20-2003 | 01:56 AM
My Feedback: (9)
Default Things to come
Recently saw a factory video on the new Stihl Four Stroke engine they are producing now. It is a dry sump engine & is oiled with a gas & oil mix like a two stroke. There is a by-pass tube from the intake manifold to the crankcase, when the piston goes up it pulls the mixture in to crankcase & back down ,back to the manifold & into the combustion chamber. It will most likely be in their whole line of their equipment. No weight figures yet for bare engine. >>>>>>>>>>>>big max 1935>>>>>>>>>>>>>>>>>>
Old 03-20-2003 | 02:17 AM
You might want to check out these threads from the past couple of weeks on the Stihl 4 stroke.
http://www.rcuniverse.com/showthread...175&forumid=37
http://www.rcuniverse.com/showthread...131&forumid=37
Lynnn
Old 03-20-2003 | 02:54 AM
My Feedback: (9)
Thanks Lynn: Sounds like there is a lot of people interested in it . Almost looks like a YS principal of operation. MAX
Old 03-20-2003 | 05:19 AM
Rudeboy's Avatar
That all sound and looks very cool, but...
Weight is specified at 7.25 pounds! Even if you can machine that down considerably, you will still be left with a pretty heavy engine.
Power output is said to be 1000 W at 7000 rpm, which will probably give you a workable rpm range of something like 5000 to 6500 and a power output of some 750 or 800 watts... that's about the same as your average .40 glow engine weighing in at 12 ounces...
You will be spinning something like a 16-8 or maybe a 18-8 prop at most...
Pro's: judging by the spec sheet that will be a very long lasting engine (probably a lifetime if maintained correctly), you will be able to muffle that thing until you can't hear it anymore, prop noise at those speeds will also be very low and you can probably fly around an entire afternoon on a 20 oz fuel tank.
Maybe it's ok as a novelty on a WWI triplane...
