kill switch
I asked this question in the nosen citabria thread with 0 replys so here it is again. I want to put a kill switch on a g38. what kind of swith must it be? It will only be a grounging switch so I assume anything will work?
d
d
You are correct, most any normally open switch will work. I have used both, the miniature toggle switches and normal size. Just keep all the wiring well forward of your radio equipment and battery, in front of the firewall if possible. 22 gauge wire is sufficient.
