OS 160 FX prop size
OS 160 FX prop size
I have a Os 160 FX in my greatplanes ultimate 160, and i run a menz 18X8 at 7700 rpm.
But i want more vertical performance, so i tested a menz 20X6 and only got 7100rpm,
and i think that is to low rpm? Will i overload the engine?
Anyone know what the best rpm is for this engine?
RE: OS 160 FX prop size
ORIGINAL: RICRAC
I have a Os 160 FX in my greatplanes 160, and i run a menz 18X8 at 7700 rpm.
How is the rpms on those props?
What i have seen the APCs turn higher rpms on the same size as menz and other, like if i would put a APC 18X8 on it i will get higher rpms than with my menz?
Will a APC 18X8 have more thrust then my menz 18X8?
rpm's mean nothing.
APC runs higher rpm at disappointing performances. Get a decent wider blade prop if you want pulling power, and test it not by rpm, but by plane performance.
Yes im with you on that, That was why i would go to a bigger prop.
Any ideas of what prop i should try?
Os says 3.7 hp at 9000rpms
And i get 7900 peakrpms on the menz 18X8 and 7300 peakrpms on 20X6 menz
What would be the best static rpm on ground?
The prop that stays below 8000 rpm will be best. When it unwinds, it should stay just shy of the max power rpm limit, which BTW is pretty much defined by the muffler you use. Paper values are just that. They work, if you are running the same setup.
G'day Mate,
I run 16x10 or 17x10 APC's on my Katana, you need more pitch not more diameter.
Try it you'll like it. Forget RPM's just fly the plane.
