what engine
My Feedback: (14)
Gene,
I have this plane and I love it. Mine has an Evolution 60 on it and it has all the power it needs. Evloution engines and very realible and easy to use. They are mid-range in price. $119.00 at the LHS compared to a OS 61 at $159.00. Each engine is very good and you won't go wrong with either one.
Good luck
Good luck
My Feedback: (16)
A two stroke engine fires every time the piston comes to the top of its stroke. They turn faster and have more overall power. they are simpler and cheaper.
A four stroke engine fires every other time the piston comes to the top. It tends to have more low end torque, run a little slower and is more fuel effecient than the two stroke. The four stroke has valves in the cylinder head like your car
They both use the same fuel and field equipment.
