glow plug for tower .75
ORIGINAL: jeffk464
I need to know what the most reliable glow plug is for the tower hobbies .75.
http://www2.towerhobbies.com/cgi-bin...p?&I=LXGWY5&P=
Flyboydave also uses the K&B1L which is also a long reach, and i've tried it as well, and it works perfect with this engine, but you have to get them from K&B.
http://www.mecoa.com/acc/glowplug/glowplug.htm
i've tried the Tower and the OS #8 which are short reach plugs.......both changed the idle transistion for the worse.
the TH .75 heads are set up for long reach plugs.........makes no sense to use short reach plugs.
My Feedback: (16)
Here's what Tower says.....
http://www2.towerhobbies.com/cgi-bin...&I=LXUR78&P=ML
"REQUIRES: Glow Plug: Tower R/C Long or OS Max #8 recommended"
But here's the URL for the Super Tiger plug
http://www2.towerhobbies.com/cgi-bin...?&I=LXGWY5&P=V
here we go again.......here is the link to the Tower plug,
http://www2.towerhobbies.com/cgi-bin...p?&I=LXJA89&P=
and yes, i had to buy one to find out it is a short, as is the OS#8.
when an engine head is set up for "long" reach plugs, it is pointless to use "short" reach plugs.
ORIGINAL: blw
This is from the Tower's Hobby website regarding their .75 engine:
hey and here is the link to the Super Tigre .75 which in the tech section says it includes the Super Tigre plug, but in the accessories section of the same engine, it says "accessories needed", and lists the Tower glow plug............(and again, it's a short reach plug)....................go figure
http://www2.towerhobbies.com/cgi-bin...?&I=LXFV76&P=0
ORIGINAL: summerwind
hey and here is the link to the Super Tigre .75 which in the tech section says it includes the Super Tigre plug(which is a long reach plug), but in the accessories section of the same engine, it says "accessories needed", and lists the Tower glow plug............(and again, it's a short reach plug)....................go figure
Seems unfortunate that only OS plugs are marked with type. I have about 50 plugs that are not in the original packaging. It takes forever to test an engine with an unknown glow plug.
Bill
Bill
