An Engine for the BUHOR
i wanted to ask, what engine should i use for my first BUHOR,
all i know is that it's supposed to be a .40-.47
now what does that mean and what r the best brands with reasonable prices
thnx for ur help and advice
BUHOR stands for : BIg Ugly Hell On Rails
a prop plane made from Coroplast u'll find it at SPAD
SPAD stands for : Simple Plasctic Airoplane Design
i wanted to ask if the engine mount is included when u buy an engine
is it a piece that usually comes with the engine?
thnx for ur repluys
thnx for ur repluys
Ordinarily engines do *not* come with mounts. If you're building a SPAD, dig around on the SPAD message boards for the details on the PTFE engine mounts and firewall. Someone is selling the pre-cut pieces cheap, but you can cut your own from a Wal-Mart kitchen cutting board (look for the word "poly" on the label). The stuff makes a great firewall - it's impervious to fuel and engine exhaust. Engine mounts made of the stuff are easily rigid enough for flight, but will flex a bit in a crash - maybe enough to minimize engine damage.
My Feedback: (21)
Well, I don't know if he's going to find a Wal Mart in Jordan (middle east).
A piece of hardwood or plywood approximately 10mm thick will work in place of the HDPE cutting board for an engine mount. Just use the dimensions in the BUHOR instructions.
ok thnx alot i just didnt know what they ment by the engine mouint and now since u gave me good alternatives i know whats the mount
i have poly here in Jordan and everywere man i know what this is and reallyb thanx for everty help
