Webra 52AAR Shim
Old 03-27-2003 | 03:25 AM
Default Webra 52AAR Shim
Last year I Bought a new Webra 52AAR for My helicopter. After one gallon of running (PowerMaster 15%) , the piston came black and the retaining pin of the ring make a spot on the top of the piston.
I think it was to lean or the Nitro was to high. I heard that Webra need to run with 5% or 10% of Nitro or else I need to put a Shim on the head.
So I rebuild everything and I put a shim on the head. But how many shim I need to run this engine properly with 15% Nitro?
Do you have any advice?
Thanks?
Serge
Old 03-27-2003 | 01:39 PM
Hi!
try onr 0.1mm aluminium shim.....at a time! You will notice when compression is right...mount the engine in a test stand and put on a 11x6 APC prop and notice how it works with different nitro contents and shims.
It takes a bit of time ofcourse....
Regards!
Jan K
Sweden
Old 03-29-2003 | 03:21 PM
How can I know when the compressionis right?
Old 03-30-2003 | 07:36 PM
Hi!
You know when you have the right compression as then your engine will rew the most and will be easy to set and throttle perfect...check rpm with a tachometer!
Regards!
Jan K
Sweden
Old 03-30-2003 | 10:00 PM
Thanks for your advice
Serge...
Old 03-30-2003 | 10:08 PM
TimC's Avatar
Where is a source for shims? The're not listed in the online K&B and O.S. cats. Thanks
