Rossi 45
Old 02-28-2002 | 09:26 PM
My Feedback: (7)
Default Rossi 45
I have a Rossi 45 2000 airplane motor and I am need of the thread size for the backplate bolts. I am mounting the motor in a quickee 500 without using a motor mount just a 1/4 plate to the firewall. Or just guide me in the right direction where I can find out. Thanks Rick
Old 02-28-2002 | 10:56 PM
splatt's Avatar
Default Rossi 45
Performance specialitys used to sell a radial mount for rossi's, I use mine to set my monokote iron on when it's plugged in. I also used the "plate" method that you descripted, it works. sorrry I can't remember what the size is though, maybe 3.5mm
Old 02-28-2002 | 11:22 PM
My Feedback: (7)
Default Rossi 45
I think you may be right 3mm is to small and 4mm is to big. Rick
Old 03-01-2002 | 02:40 AM
splatt's Avatar
Default Rossi 45
I have had 4 different rossi's when they were king of q500. great motors, aim for a prop that will do about 15,800 rpm correctly needled, which should rise to 16,000-16,200 when quickly pinching and releasing the fuel line. 9x7.5 or so. Hope the muffler is better than the pop rivet things we had to use. the pop rivets were cheap aluminium ones, replace them with stainless steel ones and put twice as many in. The only problem we saw was the variation of power they would make, some had good fitting ABC some didn't and the tach would show that . They always had good throttle response and the plugs lasted forever.
