Tower 75 transition problem
Have a relatively new Tower .75. Runs well at idle, and have the top end set 300 rpm below peak. Problem is, after running a few minutes at mid throttle, when I go to full throttle, it consistently stumbles.
Any ideas?
Frank
Any ideas?
Frank
I had the same trouble with one of my Tower .75s, very rich in the mid range with poor acceleration. The second Tower worked fine. I got a replacement carb from Tower Services. The replacement carb works great.
While I was waiting for the carb, I substituted the carb from an SK 90. It worked perfectly.
