Os61fx
Old 04-05-2003 | 05:23 AM
Default Os61fx
....Hey ...... man,?? Does'nt any one check out the tachometer readings forum any more???...I need more info on prop fitting for more speed on a 6-7 lb P51 w.m. W/OS61FX
Old 04-05-2003 | 08:42 AM
Default Os61fx
All the Time!
Happy Fly'n....
Old 04-05-2003 | 06:23 PM
Flyboy Dave's Avatar
My Feedback: (21)
Default Os61fx
I'd use an 11-71/2, or an 11-8 Master Airscrew....
or an 12-7 zinger....
Balance the prop, spinner, and backplate to get
everything out of it.
Dave.
Old 04-05-2003 | 09:25 PM
IronCross's Avatar
Default Os61fx
Get an OS .61 LA. According to MAN it puts out more power then the FX
Old 04-05-2003 | 10:08 PM
Default Os61fx
Isn't it a OS 65LA. We have a few 65LA's at our field in a big Uproar and BIG STIK and and they move out pretty well.
Old 04-05-2003 | 11:20 PM
IronCross's Avatar
Default Os61fx
I believe you are right. Guess those must be some good engines
Old 04-05-2003 | 11:31 PM
Pilotsmoe's Avatar
Default Os61fx
The la is a bushing engine
Old 04-06-2003 | 08:51 PM
My Feedback: (9)
Default Bushing Engines
Hey - don't knock bushing engines! I won many Control line speed contests in the 50's with a Fox 29X bushing engine! first class B engine I had that exceeded 150MPH!
As for more speed with the OS61FX. use an 11-7 or 11-7 1/2 APC,
get a tuned pipe or muffler (Performance Plus), and Wildcat 15% nitro - 18% oil - or put in an extra head gasket and go 25% nitro!
Phil
Old 04-07-2003 | 02:55 AM
Default Os61fx
An 11x7 works and so does a 10x8. Probably the best speeds will come from those props, probably won't gain much by going down to a 9" higher diameter prop. Any larger prop then those above, don't seem to let the engine rev into its power band.
Not knocking bushed engines, but I simply can't believe a .65 LA is more powerfull than the .61 FX. I wish he would have done the testing without the baffle in the .61FX muffler. Also, the LA muffler does offer some tuning effect. I would also test the .61 FX with the Tower muffler which is I belive about 12 bucks.
