Bent crank ? I'll fix it for free.
Old 01-22-2008, 10:08 PM
My Feedback: (10)
vicman's Avatar
Default RE: Bent crank ? I'll fix it for free.
Sheet, bar, coil, and wire are offered as cold rolled product. Plate is thicker and not available.
I will not stray any further from the topic. If you require further definition feel free to pm me.
Old 01-22-2008, 10:11 PM
Dave, have you ever straightened a crankshaft that was bent in the area INSIDE the case? Seems that would be a lot tougher to do. Perhaps a better question would be, have you ever SEEN one bent in that area?
Old 01-22-2008, 10:55 PM
My Feedback: (21)
Flyboy Dave's Avatar
Nope....they always bend at the weakest point, and that is right where the threads end,
at least the ones I've seen.
Old 01-23-2008, 04:01 PM
YUKONFLYR's Avatar
Dave - Thank you very much for your very generous offer to straighten bent cranks. Just wanted to let you know that it does not go un- noticed.
The way I see it.....if you have a bent crank, you have two options, only one if you can't straighten them and that is to replace the defective part.
Fix bent cranks instead of replacing[sm=thumbs_up.gif]
Have it done by a professional [sm=thumbs_up.gif][sm=thumbs_up.gif]
And the best part.........
For FREE!!!! [sm=biggrin.gif][sm=biggrin.gif]
Whats there not to like about that?
If I ever get a bent crank, I will be sending it to Dave,
Thanks Dave, again for your offer!
Richard
Old 01-23-2008, 10:28 PM
My Feedback: (21)
Thank you for the kind words, Richard.
I enjoy helping others in this hobby....goodness knows it's expensive enough as it is,
and the parts prices are rather high. I get a kick out of fixing things, and beating the
system out of a few bucks whenever I can, and I don't mind spreading some help
around if I can. Besides....I have a new dial indicator and stand, and a new brass
dead blow hammer to put into action....
....let the fun begin.
Old 01-23-2008, 10:41 PM
  #31
rainedave's Avatar
ORIGINAL: Flyboy Dave
That attitude is exactly what makes rc such a great hobby. Modelers helping modelers.
David
Old 01-23-2008, 10:43 PM
  #32
My Feedback: (10)
vicman's Avatar
Dave,
Do you want the whole engine or just the crank?
Old 01-23-2008, 10:54 PM
  #33
My Feedback: (21)
ORIGINAL: vicman
Dave,
The best thing for me, is to have the crankcase w/bearings, or bushings....and the crank like this:
Old 01-24-2008, 02:32 AM
  #34
ORIGINAL: vicman
Got me there ,I was only thinking of the stuff I use to work with. By the way an old trade school instructor once told me a boilermaker \welder was a sheetmetal worker with his brains beaten out.[:-] That should set the cat amonst the pidgens. Cheers the pope
Old 01-26-2008, 09:02 PM
  #35
My Feedback: (20)
Broken Wings's Avatar
Just curious Dave, have you run across any new engines that don't have a 60 degree chamfer on the big end or a center drill on the small?
So you can run the crank between centers.....
Old 01-26-2008, 09:33 PM
  #36
My Feedback: (21)
....not really....any engine turned like this could checked on centers, like on a lathe. I have
seen some older engines that were not turned on the big end... just rough cast and drilled
for the air passage.
ID:	861940   Click image for larger version
Old 01-26-2008, 09:36 PM
  #37
My Feedback: (21)
ORIGINAL: craigpuckett
I will be sending Dave a very bent LA40 crankshaft as soon as I work off this evening....
....it hasn't arrived yet, Craig. Maybe monday.
Old 01-26-2008, 09:45 PM
  #38
My Feedback: (22)
Flyboy,
Can you give a step by step for doing this? I have the tools to do this but want to confirm the approach.
Old 01-26-2008, 10:00 PM
  #39
My Feedback: (21)
....yep. I'll show exactly how it's done....no problem.
FBD.
Old 01-27-2008, 05:56 AM
  #40
I may have one for you later today. I planted my P90 yesterday and took 5 minutes of pulling and wiggling to get the saito 120 out of the ground. Will know after I disassemble it.
Edwin
Old 01-27-2008, 05:13 PM
  #41
My Feedback: (21)
Well Edwin....hopefully it's not bent....
....but if it is, it can probably be straightened.
Old 01-27-2008, 11:20 PM
  #42
I sent it out thursday Dave,like you said "maybe Monday" [8D]
Old 01-27-2008, 11:22 PM
  #43
My Feedback: (21)
....did you say the crank was stuck in the case ???
Old 01-28-2008, 12:09 AM
  #44
no,not stuck just don't turn freely,like its binding somewhere,can't tell if its the front or back bushing,or maybe the counterweight scraping the inside of the case. I didn't have any blueing to check it with.
Old 01-28-2008, 12:14 AM
  #45
My Feedback: (21)
....OK, Craig....that should be a fun one.
Old 01-29-2008, 10:40 AM
  #46
WOO HOO!! Wont be sending you a crank Dave. I got lucky. Tore it down last night. The bearings are silky smooth and I cant measure any wobble.
Edwin
Old 01-29-2008, 11:07 AM
  #47
My Feedback: (21)
....great luck, Edwin....nobody really wants a bent crankshaft....[sm=thumbup.gif]
Craigs crank didn't come in yesterday....[]
Old 01-29-2008, 08:39 PM
  #48
My Feedback: (21)
....good news....Craigs block and crank came in today....
....now, this is the way to send something like this....talk about crush proof !!!
ID:	864872   Click image for larger version
ID:	864873   Click image for larger version
ID:	864874   Click image for larger version
ID:	864875   Click image for larger version
Old 01-29-2008, 09:34 PM
  #49
My Feedback: (21)
....yep....it's kinda' bent I would say.
ID:	864940   Click image for larger version
ID:	864941   Click image for larger version
ID:	864942   Click image for larger version
Old 01-29-2008, 09:45 PM
  #50
I am glad it made it Dave,the spam container worked good I see
I guess you understand by now what I was saying about the "sticking in the case" issue.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
