Help with engine selection
My Feedback: (20)
TX
Hello all,
I'm currently in the process of completing a Warbird (ME-109). Finish weight will be 7 to 7-1/2 lbs (60inch Wing span). I'm wondering which four stroke will best suit this application. I'm not a 3D Flier, and I don't particularly care about the "Unlimited Vertical" I've seen referenced in some posts, although some vertical is necessary (it is a plane after all). The manufacturer calls for a .40 to .46 two stroke or a .70 four stroke. Anyone that can tell me if the Saito .62 four stroke would fly this size and weight well, or am I better off just getting the .70 and managing the throttle more? Has anyone flown a Saito .62 in a plane this size/weight? If so, how did it perform?
Thanks for any input.
VA
I agree with w8ye you should get the larger engine for a plane that weighs that much. I am flying a Saito 62 in a plane that weighs 5lbs and it has good power for pulling that weight, and would probably do well up to 6lbs depending on the type of flying you do.
My Feedback: (20)
TX
Ok, I looked (read scoured) around the web (third night in a row) and found a review of a P-51 with the same finish weight as mine with a Saito 82 in it. Guy loved the engine in the 7-1/2 pounder and said it flew excellent at half throttle (and could take off in 20 feet). Guess the board members have my trust now as the first question I asked I wasn't led estray. Thanks for the input folks =)
