mach .28 nitro engine help
Old 03-08-2008 | 11:40 AM
Default mach .28 nitro engine help
hi i am new to this, i just purchised a mach .28 engine for my raze. i am haveing problems with the piston sticking at the bottom of the sleeve. or when i pull the head off to fix it the sleeve comes out with plug top, what can i do thanks
Old 03-08-2008 | 12:14 PM
w8ye's Avatar
My Feedback: (16)
Default RE: mach .28 nitro engine help
If you warm the sleeve with the head stuck onto it in the oven to around 275 degrees for 20 minutes, the head should fall away from the sleeve.
Old 03-08-2008 | 10:29 PM
downunder's Avatar
If the piston is sticking at the bottom of the liner then there's a problem somewhere because it should be nice and free. If it's sticking at the TOP of the liner then that's normal but can feel bad with a car engine because there's very little leverage to turn it over. If your engine has the pull start then it can't be turned backwards because of the one way bearing used in the pull starter. One trick that might get the head button loose (so long as you can actually turn over the engine) is to loosen off the cooling head bolts about a half turn then quickly spin over the engine with the plug fitted (make sure the engine is lubricated with some fuel first). The compression will usually pop the button loose without shifting the liner.
The Mach 28 is a nice engine, so far my son has run about 20 litres through his with no signs of wear.
Old 03-19-2008 | 06:25 AM
thank u for ur help. i pulled the engine out,and took it apart. where the piston rod is attached to the main drive shaft if that is what it is called. it is rubbing part's of the engine case. i put some after run oil it it and now it works fine? what do i do when the car is allready worm and i put it to full throttle at about 2 seconds it boggs almost till idle? please help thank u
