Too Much Muffler Pressure - fuel foaming, what to do?
NJ
I have to go back to my statement, pressure above any liquid wil not cause it to foam, it will only become a pressure vessel with liquid in the bottom. If the tank has no air leaks and the pressure line is not in fluid the pressure would not cause dishwasher fluid to form bubbles. Could it be that your fuel tank is bouncing around and the fuel level is above the pressure line, did you put a bend in the presure line to bring it to the top of the tank? Don't like to add anything to the tank with water in it, Glow engines don't run on water.....Ken The "BALSA BANDIT"
