Missing Wrist Pin Pad
Hi all. I have a wrist pin for an OS Max .60 H that is missing one of the wrist pin pads. I had some extra K&B .61 Teflon pads so I stuck one of those in the open end of the pin. But, it is a very loose fit and moves around quite a bit.
Will this be safe to use? I don't think it can come out while running, but I don't know for sure. Is is possible to fabricate a homemade pad out of something? Are there pads for other engines that might be a better fit?
The first photo is the open end and the K&B pad; second photo is of the intact padded end.
David
David
RE: Missing Wrist Pin Pad
I'm prety sure they are teflon. You can buy teflon rod from Enco or McMaster Carr and turn it to fit if you have a little lathe or a friend who does. They would be easy to make.
As long as there isn't a possibility of it snagging in a port, it should be fine.
Don
Don
The OS 91 Surpass II uses teflon pads
http://www3.omnimodels.com/cgi-bin/woi0001p?&I=OSMG7742
The wristpin includes them. It gives a diameter. You might have to search through all of the available pins to find one that's right.
You can have 2 difference material for the pads: teflon or bronce. Bronce pads must be pressed into the hole while the teflon pads are lose fitted inthe hole. Some wristpins has bronce ring soldered to wrispin or has a hollowed pads pressed into the hole.
