satio 100 4 stroke engines
WI
Jjust bought a Satio 100 to replace the 91 Magnum 4 stroke, it bolts up to the engine mount just fine , but the carb needs to be rotated for the linkage to work, and the needle needs to be reached from the top of the cowling like the Magnum did, their is two srews that hold the carb on the Satio engine, but not sure if it can be rotated 180 degrees. Thanks for any answeres,
Banned
RE: satio 100 4 stroke engines
You can rotate the carb on your Saito just undo the two screws, swing the manifold out a bit and turn it around.
I end up rotating all my carbs because for some reason they all need to be the other way around on my planes.
OH
If you are like most of us, it won''t be your last!
Saitos just seem to BREED around my house. At least, that is the story I tell my wife......
