Fuel?
Old 10-02-2002 | 07:40 PM
Default Fuel?
The heli fuel is fine in the Saito, but run YS 20/20 blend in the YS engine. Even if it isn't the YS blend it's alright so long as it has 20% full synthetic oil, and 20 nitro. YS engines don't like castor, it gums up the regulator.
Old 10-02-2002 | 08:59 PM
Banned
Default Fuel?
The actual oil content of PowerMaster's "YS- 20/20" blend is about 18%. That fuel is approved by YS.
You will find that adding nitro above 20% doesn't gain as much ower as you'd think in the YS, and it can cause overheating problems.
I'd stay away from using 2-stroke heli fuel in any 4-stroke. Its safer to run 10% standard sport mix in the 4-stroke than to try the heli mix. (and the castor content of most 2-stroke blends is high for use in any 4-stroke... Valves can get sticky from castor buildup.)
