Need webra parts
Need webra parts
I have a speed .61 I got for cheap and has great compression and traded for a good carb for it BUT now I know why I got it cheap... When I went to test run it, it turned over fine and has good compression but just didn't feel right so I took it apart to make sure it didn't have anything bad in there and what do you know The crank is in 2 pieces and the pieces where locking together when I turned it over. Now I need to find a crank, The rest of the engine looks good and even the bearings are smooth but can't find any parts for it. Anyone know where to find one.
Dauntae
Dauntae
IN
RE: Need webra parts
Paul's model supply in Fargo ND. Is the unoffical webra dealer in the USA. The crank is still available and you need new bearings too. If your going to put more than 10% nitro in engine when fixed don't waste your money or time. Webra's don't like high nitro.........
I have also purchased old Webra parts from Paul's Model Supply (for a Blackhead 40):
http://www.paulsmodelsupply.com/
I'm pretty sure your engine is the 1024 model. Here's the list of part numbers:
http://www.webra-austria.at/motor.ph...e=AERO&lang=EN
David
David
Thanks guys, I definitely will look into Paul's shop. Was not sure about how much nitro to use in this engine so I tried FIA fuel that I have for a Moki, Then I discovered the crank. If Webra runs good on no nitro I'm in luck for $6 a gallon otherwise I'll be bringing 3 cans of fuel to the field in stead of the 2 I now do.
Thanks again
Dauntae
Thanks again
Dauntae
