JIS (Japanese Industrial Standard) screwdrivers
My Feedback: (264)
MD
Does anyone here know of a source for these screwdrivers? It would be nice if I could find a set in a chain store here in the US without having to mail order or buy over the internet, any ideas?
Although most new engines have cap screws, I still have many old OS and enya engines with cross slot screws, and stripping them with a phillips screwdriver drives me mad[:@]
Mike
Mike
My Feedback: (21)
RE: JIS (Japanese Industrial Standard) screwdrivers
....sometimes when a Phillips screwdriver does not fit well, it seems
too loose in the screw. If you grind a bit off the end of the screwdriver
in many cases it will fit perfectly. This applies in particular to Japanese
screws. [)]
FBD.
screws. [)]
FBD.
My Feedback: (264)
MD
Hi Dave, I tried that trick and it did help the phillips get a better bite on a good unworn screw. Worn screws are still a problem.
I'm going to order a set of the drivers from central hobbies now, thanks all.
My Feedback: (264)
MD
BTW, I did ask the SNAP-ON dealer who comes to my workplace every tuesday, and he says, "JIS screwdrivers, what's that?"
I knew I was in trouble...........
My Feedback: (21)
ORIGINAL: rcdude7
drivers myself....I make do with what I have. [)]
FBD.
ORIGINAL: rcdude7
Some of these might prove less costly...
I think not all sizes in the 5-set offered by CH are actually needed.
[link=http://www.ikaswebshop.com/hodscjis1.html]http://www.ikaswebshop.com/hodscjis1.html[/link]
[link=http://www.micro-tools.com/store/item_detail.aspx?itemCode=49-8072]http://www.micro-tools.com/store/item_detail.aspx?itemCode=49-8072[/link]
http://www.heliproz.com/prodinfo.asp?number=888101
This is the first place I ever saw them. I bought a set 5 years ago and will never go back.
Bill
Portion of post removed from post by moderator
Bill
PA
The moderator is correct. See the thread at http://www.rcuniverse.com/forum/m_69.../tm.htm6937107
I bought a $2.00 no.2 US screwdriver at the hardware store and just touched the tip with a grindstone in my Dremel tool. Makes all the difference in the world on OS engines.
My Feedback: (264)
MD
Decided to order a set of these JIS screw drivers http://www.moodytools.com/ . This outfit is located in rhode island (made in usa) and they offer a no BS lifetime gaurantee. I had to try them.
I'll post again when I get the set.
Mike
Mike
