SS25 Enya Runs & quits
My Feedback: (540)
I got an Enya SS25 on a sig wonder a swap meet special
compression good carb was gummed up.
got it running very rich side
then full throttle launch it will run for about 30 seconds and quits
very hot after landing
all bolts & screws tight
15% fuel.
any fixes or sell it for junk on Ebarf?
15% fuel.
My Feedback: (21)
RE: SS25 Enya Runs & quits
....some engines just lean out in flight more than others, and need to be set
way, way richer than what you would expect at launch. I set a .15 engine
for a guy a few years back, and it needed 12 clicks richer than what he had
it set. Launching an engine that rich doesn't seem right to the some.
It takes about 2 full laps for the engine to get to its full blast setting, and up
to full heat. It will be running rich till then. I never figured out why the smaller
engines need to be set this way.
After the second lap the engine will be set at it's optimum full heat, full throttle
run....and will reward the operater with a good, long flight.
If a small engine is over propped, it will make the problem worse.
FBD. [sm=wink_smile.gif]
My Feedback: (19)
OH
is it holding a stable needle setting before launch ?
almost sounds like it is buzzing the fuel once in the air.
Try this.. quick experiment.... use a different prop. One size larger (9x7 would do) just to drop the rpm a bit.
See how that works.
See how that works.
PA
ORIGINAL: Crazy4Flight
15% fuel.
any fixes or sell it for junk on Ebarf? NO NO NO
15% fuel.
