Cline fine
MB, CANADA
Cline fine
Finally got to run my old Enya 90 in my zero (which has a tank 2 1/4 inches too high) with a Cline regulator. Took awhile to get prime, with starter turned about 5-6 seconds. Every thing worked fine, HS needle setting was very broad and was opened more than normal; no change when plane was held vertical. These things really work! By the way, had a flex pipe on the Enya; I tapped a 6-32 hole in the shoulder of the pipe next to the threaded portion and used the pressure fitting supplied with the regulator.
