Dumb Saito Compression Question..Help
My Feedback: (126)
I have a brand new saito 62a. During my latest build, installing the mount and engine, I noticed that the engine has no compression. I have other Saito's and I've never had this problem before. There is a glow plug installed but it's never been fueled. I suspect a valve may be stuck open. I'm going to put some afterrun oil in before I tear into it. Anyone had this happen before?
One of my Saito 91s started in reverse for a few moments then stopped - this in itself is nothing new but this one had no compression afterwards. Eventually I stripped it down to find the problem and found a bit of the PTFE tape I'd used for the exhaust thread had been sucked back in and was clogging the inlet valve open. Simple to fix but a bit worrying at the time.
Perhaps something similar going on with this engine?
Richard
Richard
My Feedback: (126)
Yes BLW, I tried it both ways and nothing. I'm going to pull the rocker covers off and take a look. I like to drop some Marvel airtool oil (Great after run) down the lifter tubes before I do a break in run. I shattered a cam gear before during a breakin due to a stickey rod.
I'll give a couple of shots into the glow plug also and see what happens. It's probably nothing and I jumped the gun in a panic. I just never had this before and I have about 10 Saito's.
I let you know how it turns out.
Bob
Bob
