OS 48 Surpass
Old 05-30-2008 | 11:15 AM
Default OS 48 Surpass
Does anyone know if the OS 50 2-stroke piston ring will fit the OS48 4-stroke (Surpass)? The OS48 is discontinued.
Old 05-30-2008 | 11:23 AM
w8ye's Avatar
My Feedback: (16)
Default RE: OS 48 Surpass
The OS 52 four stroke piston ring will fit the OS 48 four stroke. They both have the same piston.
Most people on here buy their rings for any engine from Frank Bowman in New Mexico for half the price
Frank C Bowman
1211 N Allen Ave
Farmington, NM 87401-3568
505-327-0696
[email protected]
Here's the part on Tower's site
http://www3.towerhobbies.com/cgi-bin...?&I=LXCT37&P=7
While you are at it, did you know that the carburetor from a OS 52 or the Magnum 52 will bolt right up to the 48? The newer carbs are twin needle instead of air bleed.
Old 07-24-2008 | 09:40 PM
I rebuilt my 48 in exactly the same manner. I used a Frank Bowman ring, new bearings and a Magnum carb. It has now been rebuilt about a year and I have about 50, ten or twelve minute flights on it now. I have always run it rich and have finally leaned it out to just below max rpm's. Wow, does this thing run good. I have it in a Kyosho spitfire and it is really moving out now. It's performance was sufficient when it was rich but now it is awesome set just at max. My suggestion is to leave it rich for a long time to really break it in right. Franks' rings are great and will give you excellent performance from your engine. The Magnum carb will let you get a really good slow idle out of it and is really necessary if you invert the engine. Even now I tried the original carb and it doesn't like to idle to well inverted.
