expert glow driver
I have one on my saito 180.
All you have to do is set the throttle to the position you want the driver to turn on and push the SET button. When the throttle goes below that position the driver will turn on.
The REV button is the same as servo reversing.
If it operates backwards then push the button.
It can operate with 1,4,6 cells.
Hopes this help's
Any other questions just ask I still have my inst.
Hopes this help's
ID
I have the instruction for this driver If you want I will try and scan them and send them to you.
email me.
http://[email protected]
email me.
Banned
My Feedback: (-2)
Thanks guys,I figured it out.I guess normally you'd use a y-harness,but since I didnt have an extra,I slaved it to the throttle.Works the same way,plus I've got the advatage of being able to turn off the mixing function now with the flip of a switch.
