Webra 40 tapping
Old 05-11-2003 | 04:04 PM
Default Webra 40 tapping
Does anyone know why the Webra 40's have a screw/cap on the back of the engine just above the backplate?
Have aquired a used one, hence no info...
Old 05-11-2003 | 06:34 PM
My Feedback: (9)
That is to remove wrist pin for piston removal. MAX H.
Old 05-11-2003 | 06:41 PM
Novael! not seen that before..
So you can remove the piston from the top having only th remove the head !?
Thanks Max
Old 05-11-2003 | 06:51 PM
My Feedback: (9)
First you need to remove the sleeve. Been a long time since I had a Webra down but I think they went to that when the connecting rod runs in groove inside crankcase. I know Super Tiger is that way. MAX H.
Old 05-11-2003 | 06:55 PM
Thanks - not curious enought to strip it down needlessly!
Old 05-11-2003 | 07:17 PM
My Feedback: (9)
Ataboy, Why mess with a good thing . We know how it works, that thingey goes up & down & another goes round & round! When they quit then play . Have fun ! MAX H.
Old 05-11-2003 | 07:40 PM
Absolutely,
& Webras keep at it!
Old 05-11-2003 | 10:31 PM
Rudeboy's Avatar
The screw cap is there because you wouldn't be able to take apart (or assemble for that matter) the engine without it.
Procedure:
1: remove cilinder head
2: remove backplate
3: remove screw cap in the back of the cilinder
4: remove the cilinder sleeve
5: remove the wrist pin through the hole in the back of the cilinder, and subsequently the piston
6: turn the crank until the conrod has cleared the groove in the bottom of the crankcase, and then take it off the crankpin and remove it through the cilinder
7: remove the crankshaft and bearings
Assemble in opposite order... and leave it alone unless it stops running...
Old 05-12-2003 | 11:59 PM
The good ol' K&B .61 is built this way, too. So are many of OS's four-strokes except they don't plug the hole.
