Engine thread lock
Old 05-18-2003 | 03:30 PM
rajul's Avatar
Moderator
My Feedback: (58)
Default Engine thread lock
Hi guys, just a quick question - what is the best type of thread lock for the bolts and screws in an engine ? Does it need to be the heat resistant type ? Hopefully you can recommend a part number from Loctite as there's a distributor near me. Thanks..........
Old 05-18-2003 | 03:52 PM
I have alway's used BLUE loctite. Make sure the threads are clean and dry before you apply it. I avoid using RED loctite as you usually need to apply heat to remove the fastener.
Happy Fly'n.....
Old 05-18-2003 | 10:07 PM
rajul's Avatar
Moderator
My Feedback: (58)
Happy Fly'n.....
Hi PepeJ, could you kindly check what is the Loctite part number on your bottle ? Thx...........
Old 05-18-2003 | 10:51 PM
Default Loctite
Blue 242 - item #24200 Red 262 - Item #26221
Loctite should be available at any automotive supply and some Hardware stores. I have the 6 ml. tubes/bottles and that is what the item # maybe referring to?
Happy Fly'n....
Old 05-18-2003 | 11:24 PM
rajul's Avatar
Moderator
My Feedback: (58)
PepeJ, thanks! I'll check it out immediately.......
Old 05-19-2003 | 10:10 AM
Yep -- Blue is the way to go. All I use.
