1.08 o.s. fuel tank
FL
1.08 o.s. fuel tank
Hey guys, this should be an easy one. I have a practically brand new OS 1.08 and dont know the best fuel tank size. I know it can play a role in the performance of the motor.
I was planning on a 16oz tank.
what are your suggestions?
HI
RE: 1.08 o.s. fuel tank
i plan to use my 1.08fsr in a venusII, which comes with a 14oz tank...the review article in tower gave good rating for the 1.20ax and the stock tank...you might be concerned with fuel feed problems (tank position, muffler pressure, engine position, fuel lines, etc.)...i'll try to use the stock muffler, and keep the rpms high for adequate muffler pressure...btw, i have a giant ss w/ 1.60fx mounted 45-degree invert, 17x10apc, w/ stock muffler...starts on the first back flip, pulls like a horse, and taxi's back to the flightline every time...ken
HI
ORIGINAL: Kweasel
The 108 has a big carb that makes fuel draw marginal. It may have difficulty at the top of uplines.
FL
i have no issue with fitting any particular fuel tank. i was concerned with having adequete fuel pressure with the correct size tank. the tank is only going to about 3 inches from the motor. with a maximum of 5 inches of fuel line.
HI
i think you'll have no problems with that setup...imho, muffler pressure is the key...one of my engines is an os.37szh, mounted on a 10 pound heli...the carb has a 10mm bore...despite having a main tank, header tank, and lots of fuel line, fuel flow is amazingly constant...the engine uses high nitro, runs at high rpm, and is set a little on the 'fat' side...once, the muffler pressure line had an air leak at the muffler nipple...the engine leaned and quit...with that kind of experience, i've never had to use a perry pump on my planks although using a pump might improve fuel flow even more...ken
HI
ORIGINAL: Kweasel
Dont try to apply helicopter tuning specs to an airplane application unless you are using very small props. Heli carbs are too for the rpm most airplanes can use.
