Tach Readings
Old 08-15-2008 | 01:12 PM
My Feedback: (7)
Default Tach Readings
What or where is the proper location for the tachometer while taking RPM readings? Should it be behind or in front of the prop or does it matter? Thanks!
Old 08-15-2008 | 01:14 PM
Sport_Pilot's Avatar
Default RE: Tach Readings
It works both ways, but behind the prop is a lot safer.
Old 08-15-2008 | 07:39 PM
My Feedback: (7)
OK thanks! I thought so, but just wanted to be sure.
Old 08-15-2008 | 08:04 PM
rainedave's Avatar
Two advantages to staying behind the prop is that you won't have to reach over the prop arc to adjust the needle valve, and if the prop was to fly off or break, you are in a safer position. But, you should still wear safety glasses.
David
