Engine temp.
You are a trip! Instead of rationalizing what you think I was "trying to say," you should try to comprehend what I actually wrote. Maybe if you reread all of my posts you'd get a clearer idea. Nowhere did I write that physicists designed model engines
Again you said that physicists designed the componets that manufacures buy such as the metal, tools, etc. If so and they are used then physicists are taking part in the design, even if they don't know it. However physicists haven't worked in this area in a century or more. Physicists only deal with the most new research.
Just as an aside there are plenty of physicists who aren't on the leading edge of research, folks with a BS who took their undergraduate degree into the real world to make a living. They aren't all brilliant PH.Ds. I've known a few.
