Mousse can tuned exhaust
Has anyone heard of the mousse can tuned exhaust? I would like to build one for my OS 46FX but I don't how they are built or work. I don't know if I need a different header pipe or if they hook up to the stock exhaust.
There is a good drawing on the web but I don't know the link. somwone will be along to post it im sure.
a mousse exhaust is usually used behind a header to boost output of an engine. usually used on 32-46 size engines. I have seen a photo os someone useing one behind a stock exhaust to reduce noise..but mostly used for max output.
I use them on my 32sx and 46fx. the most gain was from the 32. about 1500 rpm's and an instant transition..
[Here is the link to a good diagram
