YS .63 Muffler Woes
AL
YS .63 Muffler Woes
Am I the only one who thinks the YS .63 muffler set up is a pain in the rear? The header pipe isn't long enough to clear a cowl. It's also straight, do you can't get it to angle down from the plane.
If the muffler "bulb" had the header threads straight on the opposite side of the exhaust exit, I could cut the cowl and just have the end stick out. But with the threads at an angle, it means a bigger cut and more mess!
I can order an "elbow" joint muffler from Performance Specialties for $50 plus, but the YS was already expensive enough.
Anyone have any suggestions?
My Feedback: (14)
OK
YS .63 Muffler Woes
Ditch the muffler. Pick up some aerotrend tubing and put it over the muffler header and pipe it out the bottom of the cowl. It is not much louder than using the muffler. I've been running one this way for a few years.
Mark
Mark
My Feedback: (24)
YS .63 Muffler Woes
You can't get the header to angle down, but you can certainly angle the muffler down:
I only made a cut at an angle large enough to clear the muffler.
Note that the cowl on the Corsair is pretty big. Yet the muffler still sticks outside the cowl. No complaints about the muffler from me.
YS .63 Muffler Woes
Is that a World models Corsair, A friend has one and that might be a good engine choice for him. Looks great. Can't wait to get me 63FZ running just gotta get the plane finished.
Dauntae
Dauntae
My Feedback: (506)
Re: YS .63 Muffler Woes
Tip: The muffler & header assemblies from OS .70 4C engines are thread-compatible with the YS assemblies.
So. In my example above I used the stock straight YS header with an OS muffler. This worked perfectly. I was able to set ot up so that the mufler bolted up securely from outside the cowl, so I only had to cut a hole large enough for the muffler.
View without the cowl:
I've used the remaining muffler/header bits on my WM Zen 50. Curved OS header and the stock YS muffler. Again, the idea was to move the muffler attachment point far enough away from the side of he cowl in order to minimize the amount of cutting necessary.
My Feedback: (182)
YS .63 Muffler Woes
I've been looking for a compatible muffler for YS 91AC/FZ and 120/140s. Metric 13.0 mm thread.
So far, non available because no other manufacturers use that size thread.
There used to be AAP mufflers (1 piece) available for YS 4-strokes, but not anymore.
I just got a used AAP muffler for my YS 140L. It sounds good, but too heavy at 2.7 oz. It also does not stay on the engine well even when the engine is mounted upright and the muffler is positioned straight down. Engine is right now on a test stand. Could not keep the throttle up more than a minute because the muffler kept coming loose.
Only the YS 120FZ/140FZ muffler is the one that is available, but not sure who stock them. Maybe Central Hobbies or YS Performance.
Right now, I am thinking about using the YS 91AC muffler header with a moose can for light weight muffler on 140L.
Also, for the OS muffler /header to use with YS 53/63, better look for the OS 45925000. This is the muffler / header assembly for olde OS 91 Surpass. It is much cheaper than the current OS muffler/header for OS 70/91 surpass II parts (F-4020).
Hope this helps,
Hope this helps,
My Feedback: (506)
YS .63 Muffler Woes
I was also looking for a (standard) YS .91AC muffler. I got lucky and found one here on RCU for cheap - the alternative was to use one of the one-piece mufflers which Performance Specialties sells.
