Saito 1.50 four stroke
Have Saito 120 inverted in a large Tiger Moth. I located the tank so it was centered on the needle valve. I use a perry pump mounted on the engine because the tank is 5 inches back. I use Fox Miracle Plug on it and 15% nitro fuel with 20 artificial Castor. So far mo real problems I fly at 2300 feet.
I run my saito 1.50 allready for a few years now. Now already in a second airplane. In both airplanes is was inverted and never had any problems with it.
