OS fs-40 - really old!
Hi all,
I have just picked up the above mentioned engine.
It has only few tanks of fuel, but the main problem is that the owner did 2 drill holes to the crankcase to try to remove the inner cam shaft bearing. because it was blocked.
I'd like to buy a brand new crankcase.
Tower hobbies has one:
http://www3.towerhobbies.com/cgi-bin...?&I=LXCG97&P=Z
but i don't know if it can be used (the engine is really old).
the old one has a label between the mounting holes that says: "NH" (or "HN", it can be red from both sides)
can someone help me??
many thanks
Alessandro
many thanks
Alessandro
My Feedback: (19)
RE: OS fs-40 - really old!
I'll check for you. I have 5 or 6 of the old 1981 FS-40 and a few of the FS-40S. Most parts in the block are interchangeable. Crank, piston, rod, carb, I'm pretty sure the Surpass case will work. If the holes aren't too large I would just fill them with epoxy. If you have a photo that would be helpful.
G'day I have an early OS FS 40 which I suspect is like yours. Mine has NC under the engine mounting lug. It has the letters OS on one side of the engine and FS-40 on the other side. It does not have Surpass anywhere. I suspect that your engine is like mine and that the crank case you have seen for sale is not suitable. Many of the parts are interchangeable. I think the bearings are the same and the piston ring also.
If you want a "new" crankcase, your best bet is probably to find a good used one. I would be suprised is there are still any new ones out there for sale.
The FS-40 is one of the sweetest running little four strokes you will find. Not one of the most powerful but very easy to use.
I have had the one in the photos for many years. I most recently had it in a very old Kadet Senior which it flew. Just.
I agree with a previous poster - I would try to repair the holes with 24 hour epoxy. The holes in that area would not be structural.
ORIGINAL: mike109
It needed to use the newer crankcase (Surpass) we must have new cylinder head + cover for valve and camshaft as well. The rest of all the old parts fit in recent crankcase.
Sometime are the old FS 40 to sale in EE-BBAAYY. Use it as a spareparts, it is cheaper than to replace with new parts.
I has both FS 40 and Surpass FS 40.
Edit: corrected some wrong word..
My Feedback: (16)
The letter codes you guys are quoting like "NC", "NH", or "HN" is a code of who assembled the engine at the OS factory. The letters are more or less meaningless to us as consumers. A new crankcase does not have these assembly code letter sets. So if you see a OS without these letter codes on the bottom of one of the mounting lugs, it means someone replaced the crankcase with a new part.
Hi all,
first of all many thanks for your quick reply.
here below the pictures.
The JB weld seems the best way after all.
The problem is that here we have different stuff. I'll try throgh TH.
Alessandro
Alessandro
Buy some metal epoxy and you just have it fixed.
Something along these lines
http://www.huntsman.com/advanced_mat...fm?pageID=5901
My Feedback: (20)
PA
did the previous owner ever get the bearing out, just wondering why he was trying to replace it...if you heat the case with a torch(not to much though) it'd probably almost fall out, any cold weld epoxy should fill them, just make sure the case is very clean first so it adheres well
Hi all,
a little update.
The previous owner did the holes recently after about 15 years after the breake in: the cam shaft bearing was blocked and there were no way to remove it.
anyway, I did the repair: i used a product called "lquid metal", a single part putty used to fill gap into car's exsaust systems.
As soon as it become hard (about 12 hours), it can be also polished!.
the job went well for me. have alook to the picture attached.
Now I need:
a new piston ring (missed years ago)
a new connection rod (piston to shaft) because a little bent
a new set of bearings (i want to be prepared after the secon brake in, just in case)
Many thanks to all for the usefull info.
Ill' post the result as soon as it runs again. And then, if everything goes well, i have to find an airframe
bye
Alessandro
a little update.
Now I need:
bye
Alessandro
ORIGINAL: Alessandro 78
Now I need:
Now I need:
Hi friends,
it runs!!
Preatty well too.
it isn't a powerhouse. The first readings after 1 and a half fuel tank are:
master 9x6 7.050 rpm
master 9x8 6540 rpm
zinger (wood) 10x6 6.000 rpm
I need some more test and fuel to complete brake-in the engine.
I plan to mount it into a small bipe, may be the small tiger moth from Gee Bee models (i have a copy of the drawing).
here below a couple of pictures.
bye
Alessandro
it runs!!
Preatty well too.
master 9x8 6540 rpm
bye
Alessandro
Alessandro, congrats on the engine![8D]
Those numberes seem to be a bit low, my FS-26 runs those prop sizes (mainly Master, too) and higher rpms. I know the FS-40 isn't a powerhouse, but still, it ought to turn them at a bit higher rpm... How's the valve clearance?
Banned
I wouldn't even worry about the holes. The case is open to the atmosphere through the breather so two more small holes won't make any difference. As a matter of fact they will ensure the cam bearings and shaft will have positive lubrication as the oil from blow by will move towards those holes. The only real draw back is oil coming out through them and no way to direct if away from the engine. If you really have to plug them, clean well with a solvent and use JB weld or some other type of epoxy.
Hi all
First, merry Christmas to everyone.
Today, before going to have the usual Christmas lunch, I tried the engine again, after having corrected the timing of the cam (last Sunday night).
Well, the reading now are a little better
MA 9x6
• Rpm Min 3340
• Rpm Max 10020
Zinger 10.5x7
• Rpm Min 3500
• Rpm Max 7800
In the next days I have to tune a little better the needle and balance the propeller, but I have to admit that I like this engine: greate transiction a good power.
Basically it is still brand new (only 3 fuek tanks at the moment, considering also the one that my friend did 20 years ago; he admitted that he bought it in the early '80).
Next step is find a (new) model for it .
what about this one??
http://shop.lindinger.at/product_inf...ducts_id=72974
Thanks all for your support
Bye
Alessandro
MA 9x6
• Rpm Min 3340
• Rpm Max 10020
Zinger 10.5x7
• Rpm Min 3500
• Rpm Max 7800
Bye
Alessandro
