MVVS 1.6 gasoling tubing size?
My Feedback: (14)
Considering the fact that this engine would be hard pressed to burn more fuel than a half an ounce per minute of gas/oil mix, I'd say that getting a snug fit on the fuel nipples (and securing with clamps/tie wraps) is more important than concerning yourself with sufficient fuel flow as it relates to the fuel line's ID.
Additionally, the Walbro carb incorporates a fuel pump, thus further lessening the worry about fuel delivery.
My Feedback: (8)
KS
I'm not worried about fuel delivery, I just want to make sure that it's not TOO big. The plus is that fueling the 8 ounce tank will be much faster with bigger line.
What kind of clamps should I use? I want to stay away from tie wraps.
I purchased not knowing better the 1/8" Tygon fuel line and have since tried 1) large metal spring clamps; 2) the medium of same; and now; 3) small black wire ties. #3 is the only one that works on my fuel nipples. Ryobi 31
RS2K: enlighten me as to why.....
"I want to stay away from tie wraps."
My Feedback: (8)
KS
Well, it's a lot easier to unclamp a clamp then it is to unwrap a wire. I "plan" on not using a cowl, and if I don't use a cowl I won't use a fuel filler whcih means I have to pull off the lines to refuel.
Turned/ sanded down some mini drip irrigation "T" fittings and plan to use one of those ball tipped plugs on the fueling stub on the "T"
Space is a problem at times and I wanted tight fittings as the they are all over the muffler on a gasser.
Turned/ sanded down some mini drip irrigation "T" fittings and plan to use one of those ball tipped plugs on the fueling stub on the "T" . The 'T"'s passed the submerge in gas test for a week or more.
