Refueling setup help!
Hi guys,
I just picked up a new H9 Pulse XT 40 ARF and a new OS 55ax.
Cannot wait to fly this puppy. This will be my first shot at glow flying, as I currently have 5 electric planes.
Anyway, my question is, does anyone know of a website or instructions on the best methods for refueling planes with cowl's??? I have found next to 0 info online on best setups and what parts are needed. All the guys at the LHS had no clue what parts I needed either... How do new glow hobbiests know what to buy?
Anyway, do I go with a fuel dot mounted to the side of the cowl, or a simply a 3rd line hanging down from the tank which is capped when not in use? My tank cap has 3 holes, of which I assume you're supposed to drill out the 3rd hole and insert another brass fitting and a 2nd clunk line? Or is it best to stick with 1 clunk line and just use a brass bent suction pipe??? Obviously it needs to be easy to get to as it would be rediculous to remove the cowl for every refuel. Now what happens when I fuel? Won't the carb be flooded??? 1 way valve in line to carb??? What about unfilling the tank? I'd assume a 2nd clunk line works best?
Next I bought all the hookups to drill holes in the glow fuel container lid to put 2 holes in. I think this part is straight in my mind. One is just a vent for replaced fuel. I ended up buying like $40 with of connectors and parts as I mapped it all out in my mind. Since I've never done this before it was a bit of a challenge, especially since everyone at the LHS only flies electric and has no clue about glow setups... How would the 2 line tank method (vs 3) work? I mean obviously a splitter, and one way valve, but which is superior?
I'm going to run an electric fuel pump I just bought and solder on dean's connectors so I can use my 3s lipos to power it. Should make it highly portable.
Need some help with fuel setups badly! I didn't see instructions anywhere, checked online, manuals, LHS, etc. Only site I found is [link=http://www.hooked-on-rc-airplanes.com/fuel-dot.html]http://www.hooked-on-rc-airplanes.com/fuel-dot.html[/link] but I'd like to know if a fuel dot setup is the best (or only) way to go. How do you guys all do it? A wall of over 100 parts at the LHS was a abit overwhelming, esp. when no one could help me.
Thanks!
Cannot wait to fly this puppy. This will be my first shot at glow flying, as I currently have 5 electric planes.Anyway, my question is, does anyone know of a website or instructions on the best methods for refueling planes with cowl's??? I have found next to 0 info online on best setups and what parts are needed. All the guys at the LHS had no clue what parts I needed either... How do new glow hobbiests know what to buy?
Thanks!
I see. But that would mean the muffler would fill with fuel if it's the vent line. Or how do you know when you're full? I could return the electric pump and buy a manual pump to count turns I guess. It was the same price so I grabbed the electric version.
Thanks for the replies. I guess I'll just have to build it how I think it should be and start adding pieces in line. I just figured someone would have posted instructions about this or a website on setups, as it definately wouldn't be intuitive to a new glow builder. Especially when nothing's listed in the manuals.
My Feedback: (16)
I've been trying to read your manual and they did drop the ball on hooking up the tank. There is absolutely nothing in there about how to hook up the fuel lines.
I guess it is because this is not a trainer and they assume you have built glow models before?
ORIGINAL: w8ye
What I did on my planes like the pulse is to just use two lines and fill the tank from the line that goes to the engine and vent the tank with the muffler line
when I refuel I take both lines off the engine and muffler
My Feedback: (16)
This manual tells all about how to assemble the tank but says nothing about hooking the two lines to the engine
http://www.horizonhobby.com/ProdInfo...nual_LoRes.pdf
My Feedback: (16)
Being as you seem to be a very experienced RC modeler but in Electric power, here's a section on operating the glow engine just in case you were looking for information. You may already know this?
http://www.sigmfg.com/cgi-bin/dpsmar...L+Sig+zmxg9062
Nice guide! Thanks again. I honestly can't wait to "move to the dark side of glow power".
Can't to smell the fuel and hear the engine! I have a taste of glow experience as I bought a truggy this fall. Ran 3 gallons through it, modded it a bunch and dropped in a new Picco .28. I've only just broke it in, but wow does it have balls! Double the HP and 40% more torque over the stock .28.
Cheers,
Eganwp
Can't to smell the fuel and hear the engine! I have a taste of glow experience as I bought a truggy this fall. Ran 3 gallons through it, modded it a bunch and dropped in a new Picco .28. I've only just broke it in, but wow does it have balls! Double the HP and 40% more torque over the stock .28.Cheers,
Eganwp
I tip the rear of my plane approx. 20 degrees down when refuelling. The vent pipe is then the highest point inside the tank (Kavan tank shape) and you make the area where there is air smaller. Because of that it’s easy to fill the tank close to 100 %.
Depending on the shape and position on your muffler, the fuel that went from the tank to the muffler, will come out from the exhaust exit hole.
