Magnum 46 xls & Tower Muffler "HELP"
My Feedback: (79)
I am running this combination on a 4.75lb modified Pizzaz. The engine makes awesome power from half throttle thru full throttle but is teribale transitioning between idle and half throttle. When trying to transition on the ground it will sometimes spray droplets of fuel from Carb. It will quit instantly when attempting waterfalls, you can hear it windmilling as I set up for a dead stick. I am currently running 15% 80-20 WC fuel. What can I do to try to improve the midrange, since I cannot lean the low speed any more than I have it allready? The instuctions call for a hot plug, what plug is the hottest OS#8 or Enya #3.Any replies would be appreciatied.
