OS FSa-110 question
I just received a brand new OS FSa-110 engine and I noticed a small hole in the front of the engine exactly above the camshaft room. Does anybody know what is this hole for?
If it is a crankcase pressure breather (because of the pistons movement) how it may not expel oil?
I put a small piece of metal stick inside and I felt that something soft and elastice is there.
Stelios
Yes please. Can anybody explain how is it possible to breath the crankcase from that hole but not expel oil?
Exploded view in the manual does show anything like diaphragm or anything else.
Stelios
Stelios
VA
ORIGINAL: w8ye
The crankcase in vented into the intake manifold and the engine re-uses the effluent from the crankcase just like your car does
Back on topic, however, I'd love try try out one of the new Alpha series engines, but the pocketbook just doesn't have the guts to do so.
My Feedback: (42)
Its actually to assist in removing the wrist pin when disassembling the engine.You put in a wire thru the hole to push the wrist pin out the other side.
ORIGINAL: w8ye
Those old pre-surpass engines were like an act of congress to get and old wrist pin out.
My Feedback: (16)
I learned to use the hardened dry wall or deck screws to get the stubborn ones out. Even then you have to grip the screw with pliers and leverage the pin out.
That is one of the best feelings . . . . when you finally get the aggravating old wrist pin out and you can get on with the rest of the engine repair.
Some of you refer to this as the gudgeon pin
Hello; Yes togatoga nailed it, the squishyness is the teflon pad that keeps the wrist pin from gougeing a groove in the liner. I once bought a used engine from a hapless fellow flyer, he had left the teflon pad out and now couldn't get any compression. I had to buy a new head/barrel and a lot of other parts to get it running (Saito 45 mk11), I put the "S" cam in it and donated it to our club trainer. It flew for 8 years with no further attention after that, excluding crash damage.
