Using a Tuned Pipe
Old 03-22-2002 | 12:49 AM
Default Using a Tuned Pipe
I have seen engines with tuned pipes instead of stock mufflers. What purpose do they serve? And by having one, do they add a lot of weight?
I am using my standard muffler at the moment, what can I do to prevent my plane from being covered in goo after every flight (I have tried turning the exhaust port in every direction but to no avail)?
Cheers
Steven
:rainfro:
Old 03-22-2002 | 03:40 AM
splatt's Avatar
a tuned pipe uses the pulsation of the exhaust to be "bounced back" upon itself to "pack" the air-fuel mixture in the cylinder. It can be a real shot in the arm for a 2 stroke. it may make the engine have a narrower power band. It would help solve you goo problem to have the exhaust come out futher back.
Old 03-22-2002 | 12:16 PM
Old 03-22-2002 | 01:58 PM
My Feedback: (506)
For what its worth...
I run our club's trainer. I run an OS .46FX on it, and fuel with 20% oil, all synthetic. The qyantity of Oil Goo + dust + grass clippings + chopped-up-bug-bits covering the plane and wing after a day of flying was... impressive.
To cut down on the amount of cleanup work necessary, I cut a length of 3/8" I.D. clear plastic water line long enough to run from the muffler to the tail of the plane. I rotated the muffler outlet so that it was pointing down and slightly at the fuselage. I then clamped the plastic tube to the muffler outlet with zipties. A few more ties were needed to secure the tube to the bottom of the fuselage.
This works brilliantly! 99% of the exhaust now dumps out below the fuselage at the tail - the only cleanup required at day's end involves wiping off the dust (and grass) (and dead bugs ). The engine also seemd to be a lot quieter, as the plastic tube soaks up a lot of the racket.
