new gs 45 abc engine knock
ORIGINAL: DarZeelon
That thingamajig in your photo has too short a protrusion to reach that piston....blah blah blah
As for "thingamajig", if you don't understand what it is and how it works I'll be quite happy to PM you with an explanation.
ORIGINAL: downunder
Happy now Dar? Or maybe you missed that bit where I said the protrusion was removable....
You've just made my day...
No, I did not miss that part, but the previous photo showed the 'thingamajig' with the short 'attachment', so I remarked to what you actually showed; that it might be too short for your BlueBird 'demonstrator' engine...
And mind you... that drill-bit should not be too sharp, or point at the piston... It can perforate it, if force is applied to turn the crankshaft, with a prop...
But my input; all of it, is still correct.
