Perry Pump?
Old 06-07-2003 | 02:34 AM
Default Perry Pump?
Is there any reason whatsoever to put a Perry Pump on a large size glow engine if the tank is located even remotely close to it's normal position. Thanks.
Old 06-07-2003 | 12:11 PM
JWN's Avatar
JWN
Community Moderators
My Feedback: (42)
Default Perry Pump?
Not unless you are having fuel draw problems or you simply wish to set the needle valve on a full tank without worry about it leaning out during the flight.
I personally am not running a pump on my BGX and it does just fine.
John
Old 06-07-2003 | 09:09 PM
Default Perry Pump?
I have a Perry pump on an OS 160 and it works so good OS should consider putting them in the box. I would use it no matter where the tank is, engine runs the same begining to end with no worries.
Old 06-08-2003 | 01:23 PM
My Feedback: (31)
Default Perry Pump?
pumps take away all those bubbles that you see on some of the glow motors. Its a cheap piece of mind equip that works. No matter were the tank is located, you will see that you will get to lean you high end and have the smoothest transition motor you have or will come to know.
Old 06-08-2003 | 07:27 PM
Default Perry Pump?
hi krayzc
How does it stop the bubbles ?
Tim
Old 06-09-2003 | 12:07 AM
My Feedback: (31)
Default Perry Pump?
it pumps so well that the line going to the pump will be a solid line of fuel.......
